HELP door is locked and will not open. Problem started with the door being dificult to open had to give it hard pull but now you could pull it until handle will break but will not open any ideas cheers
more and likely the door handle is broken.get a flat knife and push in between the door and cabinet if you look you might just see the catch going into the door push that back and pull door should open
