LG Washing Machine always heating water
Home Forums Public Support Forums Help And Support Washing Machine Help Forum LG Washing Machine always heating water
  • #65999
    zippy3637
    Have a LG WM1437BFD
    After a wash the washing is soo hot even if put onto a cold wash
    even after a rinse it is hot.
    Like the heating element is always on.
    Have looked on net not to find much even struggling to find parts
    Surely its a thermostat right?
    any help would be great
    thanks
    #362685
    BobHope
    Re: LG Washing Machine always heating water
    have you checked your plumbing connections as it is possible you have the hot water connected to the cold inlet valve.
    Bob.
    #362686
    QUICK FIX
    USUALLY IF ANY PROBLEMS IT WOULD GIVE YOU A FAULT CODE,IF I REMEMBER IF ITS A HOT AND COLD ITS THE HOT VALVE NEAREST TO THE SIDE OF THE MACHINE.
    #362687
    zippy3637
    Hi, have it on cold fill only.
    Even if you put the machine onto rinse it heats up the water.
    everything comes out steaming literally
    #362688
    Its worth taking the fill hose off the back of the machine and running it into a bucket for a few minutes to be certain the plumbing is correct.
