LG Washing Machine dispenser leaks
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries LG Washing Machine dispenser leaks
  • #21070
    bobokines
    Can anyone enlighten me on the issue of LG dispensers leaking? 😕
    I have a couple in my area that have started leaking from the dispenser during fill.
    Cleaning it out doesn’t seem to cure the problem. Replacing the dispenser seems to be the only answer.
    I can’t understand (or explain to my customers) why it should suddenly start leaking and what is different with the replacement part.
    Any thoughts?
    Bob
    #189388
    Re: LG Washing Machine dispenser leaks
    IIRC, there were a spate of these a year or so back – you have to replace the dispenser box.
    whitevanman
    Penguin45 wrote:IIRC, there were a spate of these a year or so back – you have to replace the dispenser box.
    You would have thought they would have taken some notice of the similar fault on the hoover soft & new wave range of machines.
    will a restrictor in the inlet valve help ? , just an idea got 2 b cheaper than replacing dispenser
    wayne
    #189390
    matkins
    Had to replace one of these only yesterday, there is a modification in the design of the replacements which one would think may make little difference, little nozzles instead of holes, it works or at least it has for the time being. I suspect hard water ultimately responsible for generating fault. 🙂
    #189391
    trotter
    The hole where the hose fits on gets blocked with scale, it is a nightmare in hard water areas. You can stop it leaking as a temp fix by unblocking the hole ……..The only permanent & reliable fix though is a new dispenser.
    Along with, of course a scale inhibiting hose which will help relieve problem and add to your profit whilst saving customer a fortune on calgon. 😯
    #189392
    trotter wrote:a scale inhibiting hose
    Que? Tell us more……….
    bazza500
    A service bulletin did come out saying models before serial no.507KW……….. need the dispenser replaced with part no. 4925ER1012A although they only mentioned model WM12397TD
