Model LD2060W, LG washing machine
On any cycle: does main wash and drains completely. Then for a few seconds each, turns on the circulation pump, then to drain pump and back to circulation pump. ‘OE’ fault code on display but machine is empty, no water at all. No water in wash tub or in sump underneath so assume no problem with drain pump although this fault code refers to this. Drain hose is in stand pipe, everything else looks ok.
Any suggestions?
