LG washing machine leak from dispenser
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries LG washing machine leak from dispenser
  • #26482
    bzz67
    LG wm1480fhd sometimes leaks a good trickle of water down the front of the machine.dispenser hose or jets not blocked.all very clean.cannot see any reason for it.
    has anyone else had this problem or even better, know a cure.
    #210352
    bazza500
    Re: LG washing machine leak from dispenser
    This was a known problem and there is a new dispenser to fix the problem, someone on this site will know the part number for the new one.
    #210353
    bzz67
    thanks bazza,thought it could only be something like that, just needed someone to confirm it.found the part on electrue.cheers.
    #210354
    agro
    when you fit your new dispenser check the water pressure as even the new ones can leak if to high saves a recall
    #210355
    Lawrence
    I have fitted two in the last month for the same fault you describe ,both fixed okay ,The jets look like they are now angled
    Lawrence
