Hi There
Was hoping for advice on here
Had a drainage issue with my LG washer
Did all the usual:
Checked drain
Checked pipes
Took washer apart
Checked filter
Checked drain hose (that was blocked and cleared)
Checked the large pipe from drum (removed a few coins)
Took out pump Tested and works fine
It’s like the bugger hates me so not sure where else to look..
Is there a potential other issue that I’m missing?
There are the pipes leading from the pump to main drain I blew through and no blockage there .
Help (if possible?)
Thanks a Mill
Alan
:con:
