Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › LG washing machine Rotors & Stators + Hall Sensor
- This topic has 10 replies, 5 voices, and was last updated 14 years ago by
TeeMyob.
March 29, 2012 at 8:52 am #68688
TeeMyob
ParticipantHello,
Are the LG Motor Rotor & Stators on the washing machines interchangeable please?
Connect list a couple of different part numbers (and vastly different prices).
I attended one with an LE error yesterday. When I fitted the coil I had on van stock, the same problem flashed up.
Anyone help please?
TM
March 29, 2012 at 4:22 pm #372266QUICK FIX
ParticipantRe: LG washing machine Rotors & Stators + Hall Sensor
could still be pcb have had that b4
March 29, 2012 at 6:08 pm #372267TeeMyob
QUICK FIX wrote:could still be pcb have had that b4
Thanks Quick Fix
Had never given the PCB a single thought!
TM
March 29, 2012 at 9:12 pm #372268stevebunyan
ParticipantLG washing machine Rotors & Stators + Hall Sensor
TeeMyob wrote:Hello,
TM
interchangeable on smaller capacity models but not with the 12 kg models
Sent from Steves
iPhone using TapatalkApril 30, 2012 at 8:02 pm #372269TeeMyob
Still having troubles.
The machine has had a new Stator and a New PCB.
Did one whole wash and at teh last minute made the dreaded noise.
Tried a spin cycle and it then came up with LE.
Took back off, tightened rotor. Put on a Spin only (15 mimutes). It wnt to 10 minutes. Puts water in, drains water out then stalls.
Any Suggestions?
TM
May 2, 2012 at 7:48 pm #372270deltra
only ever had the stators go faulty!! every time it came up LE.(R U ON MHF TM?)
May 2, 2012 at 8:19 pm #372271Hollytree_Technical
If the rotor is coming loose then has it stripped the splines off of the plastic hub in the middle of the rotor? If so then the noise could be the remains of the splines slipping on the shaft (unless it is a completely different noise that you are talking about), the way to test if it is slipping is to hold the drum and try rotating the rotor – if it moves then the splines have gone.
I may be barking up completely the wrong tree but thought that I would throw the idea in there for you.
Jem
May 3, 2012 at 8:56 am #372272TeeMyob
Hollytree_Technical wrote:If the rotor is coming loose then has it stripped the splines off of the plastic hub in the middle of the rotor? If so then the noise could be the remains of the splines slipping on the shaft (unless it is a completely different noise that you are talking about), the way to test if it is slipping is to hold the drum and try rotating the rotor – if it moves then the splines have gone.
Jem
I am thinking it could be the rotor (if it is very very tight, it seems to work for a while)
Thank You
May 3, 2012 at 8:58 am #372273TeeMyob
deltra wrote:only ever had the stators go faulty!! every time it came up LE.(R U ON MHF TM?)
Yes, That is I on MHF. The one with all the wit and charm and a little knowhow.
Are you?
TM
May 4, 2012 at 3:37 pm #372274deltra
yes, but i say very little!(i mention windemere swim occasionally)
May 15, 2012 at 9:26 am #372275TeeMyob
deltra wrote:yes, but i say very little!(i mention windemere swim occasionally)
I have seen those posts!
Not sure who you are but have an Idea.
TM
