LG Washing Machine WD – 1253FHB
Home Forums Public Support Forums Help And Support Washing Machine Help Forum LG Washing Machine WD – 1253FHB
  • #32585
    Andrew B
    The machine showed error code dE. I understand this is ‘door error’. I replaced the door interlock but still get the same error. Where do I look next? I am a fairly well experienced electronic engineer. Thanks for any info. This is my first post so please forgive any errors and feel free to correct me. Cheers, Andy
    #235701
    BobHope
    Re: LG Washing Machine WD – 1253FHB
    hi andrew B,
    check the door handle pin has not come out of its fixing holes, to do this you need to dismantle the door assy.
    Bob.
    #235702
    Andrew B
    Thank you Bob, I’ve checked the hinge end of the door and all looks secure. The catch swings into the interlock cleanly. Any other clues?
    Andy
    #235703
    BobHope
    Hi Andrew B
    have you dismantled the door frame and looked at the handle pin itself
    Bob.
    #235704
    Andrew B
    Bob, No, not yet. I’ll look at the hinge end properly tomorrow. I only really looked at the interlock and assumed that was the only electronic means of determining door closure. Are there electronics at the hinge end?
    Thanks, Andy
    #235705
    BobHope
    it not on the hinge end, its behind the handle.
    bob
    #235706
    Andrew B
    Bob, Thanks again. I’ve just had a look at the hinge end and, of course, there’s nothing electronic there. I’ll dis-assemble the handle and have a look. Cheers, Andy
    #235707
    Andrew B
    Bob, I took apart the handle and yes, the pin had dropped. Re-assembled and connected back up – still the same. I tried the original interlock back in – still the same. Any further thoughts? Cheers, Andy
    #235708
    BobHope
    hi Andy
    please take your time and backtrack all that you have done as the pin problem quite common, check that the door has been corrrectly assembled.
    good luck.
    bob
