LG WASHINGMACHINE WM1480FHD
Viewing 10 posts - 16 through 25 (of 25 total)
  • #208562
    machineman
    2 but on the wm13220 fd part No6871er1009a motor makes a dreadfull noise going into spin with it loaded .empty still sounds a little rough ,we changed the motor but it was still rough , changed the board and it was quite as a lamb ,you can see the bulge on the cap where it has blown.
    p.s this mod is up in the console .m
    #208563
    funkyboogy
    Re: LG WASHINGMACHINE WM1480FHD
    sorry for late reply guys..
    to recap problem…appliance is pretty smooth on wash, but on spin it starts up smooth-then makes the rough noise leading up to full spin,
    if you switch appliance of at wall whilst spinning it is almost silent…
    appliance is about 25 miles away and we are doing it as a favour for a commercial client..
    engineer that was at appliance didnt have a good look at module but did suspect a module/motor speed issue,
    cheers… and thanks for mail bob…
    #208564
    funkyboogy
    bob can you resend mail, i deleted it by accident…
    dohhhhhhh
    ally
    #208565
    BobHope
    Hi Ally,
    please check your PM
    Bob.
    #208566
    funkyboogy
    thanks bob..
    thats a great help.
    did i forget to mention the customer has said the display had indicated a
    C.E FAULT ??? = pcb/winding in stator faulty
    dohhhhhhhhhhhhh
    #208567
    funkyboogy
    C.E FAULT = PCB , MOTOR WINDINGS ?,
    if the windings were faulty would it still ..wash/spin..
    ally
    #208568
    BobHope
    Hi Ally
    page 29 off the service manual gives you simple resistance checks to preform, but please do check for a bearing seal leak onto the direct drive motor connection as i have had that one quite a few times, new bearing and seal assebley and a good clean up of the offending connections usually sorts it.
    good luck.
    Bob.
    #208569
    funkyboogy
    cheers bob,
    will order,
    pcb,
    windings
    bearing and seal just to make sure,
    high cost isnt an issue, i just want to complete it at nxt vis…
    cheers ally
    #208570
    bigkid
    What was the upshot of this?
    I had a call a few weeks back where the customer complained of the noise you descibed. Naturaly enough it didnt do it for me (unlike the customer … stunner)
    I am happy to say she phoned again today holding the phone to the machine and it sounded like a train on rusty rails.
    This capacitor mentioned, is this a common fault?
    Regards….
    Tony
    Oh, machine is a WM1622OFD
    #208571
    barryfast
    Hi went to one today ! same fault was not the module i tried that got on to
    LG tec they told me motor stator fault wen i fit it i will come back to let you know barryfast
