LG water dispenser problem
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum LG water dispenser problem
  • #28861
    jglaister
    My water dispenser has a reduced flow rate.
    I have trawled through these forums and there seems to be many problems with people not getting any water from the water dispenser. I am still getting water but it has now been reduced to a trickle. It takes ages to fill a glass, probably about 3 or 4 times as long as it used to. It has been like this for a few weeks and has not got any worse. Can anyone give me any ideas as to what might be the problem?
    The model I have is an LG, GRL227KGHA, side by side fridge freezer with water dispenser and ice maker.
    Jeff
    #220426
    Re: LG water dispenser problem
    When was the last time you replaced your water filter ?
    Are you using a genuine filter ?
    how old is your appliance ?
    Bryan
    #220427
    jglaister
    Hi Bryan,
    thanks for getting back.
    I have never replaced the water filter
    the appliance is just over 2 years old
    Jeff
    #220428
    Then start with that then as water filters need to be changed minimum every 6 – 12 months
    Bryan
    #220429
    jglaister
    will do
    thanks
    #220430
    jglaister
    Hello again,
    I have now replaced the filter.
    Unfortunately this hasn’t fixed the problem. Also, now when you stop demanding water it takes a while to stop, maybe 10 or 15 seconds. It’s like a valve closing really slowly. I was wondering if it could be a valve that’s sticking. Am I on the right track or am I talking rubbish?
    Jeff
