This machine fused plug, now shows – – – in display together with all leds.
Door can be opened but then only by turning power off and then on again can even that display be seen.
Any ideas about what is happening, don’t get as far as error messages!!
Thanks for any help
Sounds like the computer is a bit potty. Why did the fuse blow in the first place? You may have a “cause and effect” fault – the first fault creating the second.
The LG is a complex machine, I would suggest that you check Directories or Repairs@ for a UKW repairer in your area.
