Re: LG WD-1243FH bearing change.
Two types of tub construct……… If you’re lucky, you’ll have a tub with a ring of clips around the front plate. This can be removed with the tub in situ and the job’s a doddle if you are confident using a seriously large hammer and drift.
If you’re unlucky….. The tub will have a ring of bolts around the centre line of the tub. Tub has to come out through the top of the casing and be split, after that, it’s fun time with the hammer again. Diagrams of hoses, suspension and wiring are essential – there is no tech support available.
Otherwise, check the condition of the shaft very carefully for gouges and marks. If it’s damaged, the drum support is very expensive and you may need to reconsider what you are doing.
Power off at all times, of course.
