Lg wd door not unlocking
  • #75915
    pmb
    Hi I have a lg wd12124rd which will not unlock the door unless I unplug it, when I plug it back in it locks again. The machine works ie fills,empties and spins. I originally had to replace the handle and it worked fine when I tested it. I got a callback the next day and when I went back the interlock wouldn’t lock so I ordered one and replaced it today but now have the above problem. I found a wire had broken from heater, checked heater and disconnected just in case. I checked pressure system which was fine, so I am wondering if I have missed anything or if the PCB has blown? any advice would be really appreciated 🙂 thanks Peter
    #396594
    Allsorts
    Re: Lg wd door not unlocking
    Check pressure switch and tube
    #396595
    pmb
    Hi allsorts thanks I checked them both and they are fine
    #396596
    Allsorts
    The lock itself then… I would assume a short within the lock.. There is no real way of testing this other than to use a wiring diagram and do voltage and continuity tests.
    George
    #396597
    Allsorts
    either that .. or if you have separate wires that connect to the board/pressure switch.. make sure you haven’t put them on in reverse order
    George
