LG WD1045FH Motor problem
  • #9387
    Sparkcymru
    Hi, got an LG WD1045Fh washer with standard brush motor. The motor struggles to turn the drum now and then especially under full load and it doesn’t run smoothley. Just buzzes when its stuck till it turns the opposite direction and then carries on until stuck again. Brushes replaced, belt ok etc.
    Any ideas?
    Steve
    #133794
    Re: LG WD1045FH Motor problem
    Welcome on board Steve – sounds like armature losing the will to live.
    Cheers,
    Sparkcymru
    ok well i’m going to stick a new motor in it since they seem rather cheap from SEME and see what happens
    Steve
