LG WD12126RD Stops Starts
  • #42030
    Kirk
    I have this problem at 36 mins, it will fill/ empty for an hour or so then carry on, no fault code comes up.
    The original fault was DE and interlock changed, it also sometimes goes straight through. If you pause it overnight the same fault is there, so its not overheating, switch off at mains will then go through no problem.
    I have changed main module, facia board, outlet pump, pressure switch sump hose, pressure switch, pressure tube,heater, solenoid valve, I am now going to change the motor. I have been told to change mains filter but don’t have one, can’t see how that can be the prob but will try anything.
    Thanks Kirk
    Lucky Goldstar
    #272155
    smartin
    Re: LG WD12126RD Stops Starts
    it sounds like its siphoning, have you checked outlet hose to make sure its not pushed too far down wastepipe ?
    #272156
    Kirk
    No its not that also new waste pipe fitted, just fitted new motor and its gone through but it often worked 2 or 3 washes then went faulty, so will try it on various ones again, but I don’t think it is cured.
    Thanks Kirk
