LG WD12126RD Washer Motor locking up
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries LG WD12126RD Washer Motor locking up
  • #55692
    myfil
    Went to an LG WD12126RD Washer displaying an “LE” fault code. The one with the direct drive motor on the back of the tub. On any rotation, the motor makes jerky motions, then locks up solid – can’t move it. With the power off the drum rotates freely, no problem with bearings.
    I’ve been told it is the Hall sensor, built into the stator coil assembly but available separately as part No 6501KW2002A – but I cannot find anyone who stocks it. Or do I have to buy the whole stator coil assembly?
    Can anyone help with this?
    Cheers
    #324780
    Re: LG WD12126RD Washer Motor locking up
    just looked…..
    in stock…..with connect distribution…..@£16.94…….to me
    canufixit
    #324781
    aqualectric
    Stator has failed – 5031687978486 on Connect @ £98 + VAT.
    Steve.
    #324782
    myfil
    Thanks guys.
    Am I right in saying that if I buy the stator (coil) assembly this includes the Hall effect sensor?
    If this is the case it might be wise to play safe and buy the stator assembly..
    #324783
    I did one last month and it was only the sensor….?
    And yes …. The field dose come with the sensor……
    Canufixit
    #324784
    Cras
    just a quick word of warning i had one last month with same error code that turned out to be the board . I noticed that the large black capacitor on the old board was slightly domed on top 😉
    #324785
    Cras wrote:just a quick word of warning i had one last month with same error code that turned out to be the board . I noticed that the large black capacitor on the old board was slightly domed on top 😉
    yep good point… cras ………. had that one as well……so take a look at that also….!
    canufixit
