LG WD12311RD direct drive washer drier.
Reported fault:- loud bang and the machine trips the electric everytime it is plugged in. (didn’t pop the fuse in the plug).
Checked everything with an insulation meter – elements, stator, drier parts…all OK. 😕 So I tried the machine on my PAT tester. Earth and insulation readings were fine; but when I went to start the function test, the display on my PAT said “Load too great, do you want to continue?” Obviously I declined……. 😯
My thoughts are the main inverter board is at fault, anyone had this problem? I cannot see a fault as the board is encased in resin. Fascia PCB or Main PCB? Also I am intrigued why the PAT tester gave that “Load too great” result. Morbid curiousity……. 😀
Any help please!!
Steve.
