LG WD12336AD Drum Paddle
Home Forums Public Support Forums Help And Support Washing Machine Help Forum LG WD12336AD Drum Paddle
  • #70943
    grahamhill
    Please can someone help me.
    Bought the correct spare part but cannot work out how to fit this. Even had washing machine repair man come out, unfamiliar with the machine, but he could not fit it.
    Seems that it clearly has small tabs that slide in but the edge of the drum does not allow you to access the slots.
    Be extremely grateful for any advice.
    Thanks in advance.
    Graham
    #379429
    Re: LG WD12336AD Drum Paddle
    They’re a nightmare to fit from what I understand, we usually warn people on the store about it as from what I’ve been told you have to break some of the tabs to fit them or, take the drum out to do it.
    I’ve never done one though.
    Jackal
    Yes I understand it’s a drum out job, not sure if it is model specific but I understand one part of the paddle is screwed in and you can only access the screw once you have split the tubs.
    Jackal
    Sent from my iPhone 4s using Tapatalk
    #379431
    bazza500
    Taking the drum out makes no difference on this. The paddles are fitted before the drum is formed. The only way to fit a new paddle is to cut half of each tab off otherwise there is not enough room at the front of the drum to slide it in.
    #379432
    Turbo
    Looks like your suggestion is the answer bazza as I was the engineer that went there and it had me baffled and like you say the paddles must have been fitted before the drum was formed.
    What planet are these design engineers on!!!!
    #379433
    bazza500
    The first time I came across this was an under warranty call and this was the answer from LG technical.
    #379434
    grahamhill
    Thanks for all this valuable info.
    Bazza – be great if you could tell me which half of the tab to cut off?!
    Many thanks
    Graham
    #379435
    bazza500
    Just put the paddle hard against the front of the drum then mark the part of the tabs that don’t line up with the large part of the slots and cut that part off.
    #379436
    grahamhill
    Will give it a whirl.
    #379437
    grahamhill
    I had a look at cutting part of the tabs off but was concerned there wouldn’t be enough left to hold it in place.
    Decided to cut a small section off the sloping back end to about 2/3 the way up – this sits pretty flush with the drum rim so can’t see clothes getting caught. Anyhow clipped into place nicely.
    Thanks for the suggestion Bazza – gave me the confidence to sort it out myself.
    #379438
    timroberts
    Firstly thanks for this site!
    After an afternoon of frustration, tried chopping off half the tabs as suggested here – this works just fine (Hooray)!
    My advice:
    1. If one paddle breaks buy two spares as they are cheaper than your time, and leave room for error (and the tabs breaking again)
    2. The paddle is assymetric, so offer it up to the drum and establish which end needs to be at the front of the drum, by matching the paddle tabs with the drum holes. Mark the front of the paddle with an ‘X’ using a DVD or laundry pen, to avoid a slip-up.
    3. Using a pair of side cutters, cut off 1/2 the tab, at the end furthest away from the the ‘X’ (ie furthest away from the front of the drum). This part of the tab (on my spares at least) is tapered – this being the bit you cut off.
    4. There are three metal tabs in the drum which prevent the paddle from slipping out of the tabs once in place. Ensure these are all prised up at least 1/8″ so they grip the paddle and prevent it sliding out.
    5. Slot your paddle in, and ensure that it can’t slide off. (If it does repeat step 4).
    6. Simples – if you know how!
