LG WD12336AD Washer Dryer
  • #64575
    mike412
    Not had much to do with these, looking at this one for a friend.
    Problem is the motor seems to be “snagging” and causing the machine to fault to “motor overload”.
    I think that the problem arises from a small amount of play in the drum bearing. Anyone got any better ideas?
    Thanks in anticipation,
    Mike.
    #357443
    QUICK FIX
    Re: LG WD12336AD Washer Dryer
    is it direct drive because when they run they make a strange noise aS if it was turnning but it doesnt appears to stick either pcb or the stator
    #357444
    mike412
    Yes, that sounds about right. Thanks for the response, Mike
