LG WD1243FHB
  • #6179
    tonyclifton
    Blocked
    Got above machine fault is flashing up CE which i thourght was current error checked the motor and seems fine motor windings ok. already had new module by last engineer 2 weeks ago
    any ideas?
    #116083
    Re: LG WD1243FHB
    hi Tony,
    the power cards are not reliable on these and I would not put to much faith in a new card. CE is current error and the motor stator short circuit is the only listed cause other than board failure.
    Email me a fax number and i’ll send you a copy of the error codes.
    kevin
