Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › lg wd1253
- This topic has 10 replies, 4 voices, and was last updated 21 years, 7 months ago by
machineman.
August 25, 2004 at 8:58 am #6106
machineman
Participantwe have one showing de which is door open changed door switch same error replaced main board same error.there is only one live to switchside of interlock nothing on bimetal strip contacts help please. M
August 25, 2004 at 9:08 am #115681BobHope
ParticipantRe: lg wd1253
Hi Machineman,
have you looked to see if the door latch assy is sitting at the correct position, we have had abt 6 of these LG machines showing DE errors and all of them had a bent latch pin on the door assembly,Cheers Bob
August 25, 2004 at 9:14 am #115682machineman
we have had the thing in pieces m/c works if you push the contacts of the switch. the problem seems to be on the feed to the time delay part any idea where that feed comes from M
August 25, 2004 at 9:25 am #115683BobHope
have you get the full model no.
Cheers Bob
August 25, 2004 at 9:29 am #115684machineman
WD1253FHB SER002KW00483
August 25, 2004 at 9:30 am #115685machineman
COULD be wm
August 25, 2004 at 9:35 am #115686BobHope
Do you have access to the LG Electronics web site. if not i can download the wiring diagram for you if that will help, just PM your email address.
Cheers Bob
August 25, 2004 at 1:16 pm #115687machineman
cheers bob we have access to the site not a lot there on the wiring .M
August 28, 2004 at 7:25 pm #115688knobby
Bit of a delay here but.
If the machine operates when you operate the door switch manually its got to be the door latch i have as the last reply, fitted many doors due to damaged door latches or somes times doors that look ok, i had to fit complete doors as thats all LG supply , The LG Web site is not perfect but all of the tech info is there one tip display all uk products and then scroll down to the one you require.
KnobbyAugust 29, 2004 at 10:57 am #115689machineman
thanks knobby but it only works when you take the door switch apart and push the contacts together if you just move the slider nothing works and up pops the fault code .m
August 29, 2004 at 6:39 pm #115690admin
KeymasterRe: lg wd1253
hi,
if this helps its the LG switchboard number 0870 607 5544 go to option 3 and then follow the prompts thro to technical, maybe they can assistkheath
