been here today first one i have been to when uoe select wash it starts to fill and the drum wobbles for a few seconds then starts to tumble but sounds like a bag of spanners but if you turn by hand the drum sounds fine.are the direst drive stator or rotor prone to fail and would they create these symptons.
i have had the module cause this problem aswell, 1st though check the wiring from stator when it meets the base as i have also had them wear through at this point causing same problems and taking out pcb.
Could be the hall effect sensor on the Stator at fault. I know they usually come complete with the Stator but I think connect are able to supply just the sensor – (part no. lge6501kw2002a) if you want to give it a try.
