Machine begins to fill, as soon as water visible in basket, drain pump starts and keeps pumping out the water that is busy filling. A regular slow click is also emitted from the “drain motor” (not pump).
Any ideas?
Thanx Andy
Is there no error being displayed on the control panel Andy ?
We had a similar problem with one of these when the motor was pulsing every so often and it turned out to be the control unit (PCB), after three attempts at getting one that actually worked it was fine 😉
Dave; I checked it and I get an F on the display when I select the FUZZY, JEAN or FAVOURITE programs. The others display the time for wash,rinse and spin. I can’t say for sure that the F is an error code since the machine has a seperate display for the basic errors like FILL, DRAIN, SPIN and DOOR OPEN.
Thanx
