Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › LG WM 1280FHD BEARINGS NOISEY
- This topic has 10 replies, 7 voices, and was last updated 19 years, 11 months ago by
alro.
May 8, 2006 at 10:45 pm #17673
alro
ParticipantJUST ASKING HAS ANYBODY HAD THIS JOB TO DO
HELP ON WHAT TO LOOK OUT FOR AS NEVER DONE THEM BEFORETHANKS
ALROMay 8, 2006 at 10:56 pm #175697Penguin45
ParticipantRe: LG WM 1280FHD BEARINGS NOISEY
Think Hotpoint 95 and you won’t go too far wrong……..
May 10, 2006 at 9:41 pm #175698alro
THANKS CHRIS MORE LIKE A ZANUSSI BUT TUB TAKEN OUT FROM TOP OF CABINATE SPLIT TYPE REMOVED DIRECT DRIVE MOTOR FIRST
THE FEAR TAKEN OUT OF JOB BY SAYING IT WAS LIKE HOTPOINT 95
ALROMay 10, 2006 at 11:17 pm #175699eastlmark
ModeratorRe: LG WM 1280FHD BEARINGS NOISEY
Pretty sure that tub comes out the front, far easier that way.
BTW caps lock off next time, Alro.
May 11, 2006 at 3:15 am #175700admin
KeymasterRe: LG WM 1280FHD BEARINGS NOISEY
Hi Alro
This may have the old style tank which has the front of the tub plate that comes off or that the tank comes completely out of the front in one go dependant if the bearings have ben changed previously.either way the thank can come out of the front of the machine.
bryan
May 11, 2006 at 7:30 pm #175701AMS
Hi guys,
I’ve just had an enquiry about a bearing job on a LG WM1460FHD. Before I take it on, I just wanted to know if it’s pretty much as described previously. Does it being direct drive cause any aditional complications? Anyone got a number for the bearing kit and any other parts required. What are the bearing sizes?
Cheers,
May 11, 2006 at 7:54 pm #175702farmboy
Dunno about bearing sizes but the tub design is similar to the Zanussis and will come out through the front. Direct drive system is easy – remove the pulley(rotor) then unbolt the winding assembly.
May 11, 2006 at 8:03 pm #175703AMS
Thanks Farmboy. 🙂
May 11, 2006 at 9:38 pm #175704alro
AMS or DAVE
PT No 4280FR4048E BEARING
4280FR4048D BEARING
4036ER3002A SEAL BEARING
4036ER4001A TUB SEALSEME NEDIS CD
HOPE THIS HELPS EASY TO TAKE TUB OUT OF TOP OF CABINATE ONCE
YOU HAVE REMOVED DRAW AND WATER VALVES LAY ON ITS SIDE .THEN THERES NO MESS TAKING THE FRONT OFF JUST DIRECT DRIVE MOTORCHEERS ALRO
May 12, 2006 at 6:39 pm #175705AMS
Thanks very much Alro. Sounds pretty straightforward.
May 15, 2006 at 4:14 pm #175706CDS
You can get the back half of the tub, which makes life a lot easier.
If you do go down this route it is worth ordering in a heater as well as 95{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time they leak when you put them back.
