LG WM-1285FHD
  • #18041
    Bryan
    Called out to this machine today with repoted fault of drum overfilling with water. Customer put machine on and sure enough it was taking in too much water. Stopped it , drained water and had a quick look at pressure hose and vessel , both of which seemed fine.
    Decided to try machine again you`ve guessed it……everything ok :?.
    Tried it again on several different settings and worked fine every time.
    Don`t work much on LG machines and wondered if anyone knew of any common overfilling problem as I hate leaving a machine like this although customer has been well warned to keep an eye on it.
    No error code.
    Strange looking pressure switch , do these cause problems ❓
    Any help much appreciated.
    Bryan
    #177499
    Dave_Conway
    Re: LG WM-1285FHD
    Bryan wrote:Strange looking pressure switch , do these cause problems
    Generally no, they are the “analogic” type, they change resistance as the pressure increases and rely on a low power (5V-12V I think :?) to work.
    Probably an air lock or there’s a tiny hole/split in the pressure tube/chamber ?
    #177500
    Re: LG WM-1285FHD
    If it’s anything like the machine I was doing the hose is ribbed so it would be difficult to see a hole.
    #177501
    agro
    Good way to check the tubing fill the sink with water hold one end and dont get carried away blow till ya harts content. Ive had this and just cleaned the tubing and sump did’nt get a call back ages ago now
