LG wm-13220fd OE code not spinning
Home Forums Public Support Forums General Enquiries And Questions LG wm-13220fd OE code not spinning
  • #67978
    stewartm
    Hi i have a lg washing machine which stops at end of drain cycleand brings up OE code which looking on line tells me that there is still water in machine so will not carry on to next programe. i have checked filter and also cleaned out drain pipe there is no water in the machine but still getting code and door locks
    Could there be a fault in the sensor which senses if there is any water present if so is this the hall effect that is a fault
    #369210
    Could also be a blocked air bottle which is on the inside that tells the machine it’s got a level of water.
    Bryan
