LG wm 1460 FHD & wm 1280 FHD Bearings
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries LG wm 1460 FHD & wm 1280 FHD Bearings
  • This topic has 5 replies, 3 voices, and was last updated 18 years ago by M1.
  • #35211
    M1
    LG direct drive WM
    (two bearing job to do this week !! LG bearing virgin !!)
    I have got the outer tub out of the machine and split it, but how do I get to the six bolts holding the direct drive to the outer tub ? the outer guard of the direct drive is held internally by three bolts, and can’t be un-bolted from the outside, the fins are to close together to get a socket to the remaing bolts any ideas ??
    #245531
    lerch
    Re: LG wm 1460 FHD & wm 1280 FHD Bearings
    H if you are changing the tub and not just the bearings becareful as new tub has holes for direct drive indifferent position. 🙁
    #245532
    M1
    I want to just change the bearings & seal but can’t seem to figure out how to get the direct drive off !!
    #245533
    The Direct drive unit is held on by one bolt in the centre,the stator is then bolted onto the rear of the tub by about 8 bolsts
    Bryan
    #245534
    M1
    I have undone the center bolt, do I just pull the direct drive off I have tried but it does not seem to move !!
    #245535
    Yep,Its just a pull off,Its only got a nylon bush in the centre.
    Bryan
    Lucky Goldstar
