Re: LG WM-1465FHD
Hi Charlie,
I’m not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure but this code might mean that the load is out of ballance so the machine will not do the fast spin.
There are various causes for this :- overloaded, very small load, washing one heavy item, machine not level on the floor.
All of the afore mentioned can cause the control module to default to out of ballance mode.
Try adjusting the load and check the filter, also check that the machine is level. If all of these fail to cure the problem then I think you would be best advised to call in an engineer. HTH
Regards Del
