LG WM-1485FHD dE code
  • #103371
    Kiza40
    My old washer has started giving dE error code on programme start. It throws dE, beeps 5-6 times then the error disappears and starts a normal wash. It happens on every single start and then begins to wash. Is it a faulty door lock or a PCB? Many thanks!
    #492892
    dE is a “door error” so it thinks the door isn’t closed for some reason. If it is closed correctly the door lock is the most probable cause of it.
    Kiza40
    kwatt wrote:dE is a “door error” so it thinks the door isn’t closed for some reason. If it is closed correctly the door lock is the most probable cause of it.
    If I start the wash with the door open it throws dE and obviously would never start. But when I start with door closed it shows dE, for about 5 seconds, and then the display shows the remaining time and it starts the wash. If I try to open the door, during wash, it is locked as it should be. If I start the wash with a door open it throws dE, but as soon as I close the door it starts the wash.
    #492894
    Which would suggest the lock isn’t communicating the correct status for some reason at the start of the program.
    Kiza40
    Thank you for your reply. Most likely a main PCB issue, drying capacitors
    #492896
    I’d not assume that, it’s not the most likely reason.
    Kiza40
    So what do you think the most likely reason would be?
    #492898
    I told you, the door lock. Possibly the wiring but that’s more of a long shot.
    The board is reporting the error as it should by what you’ve described.
