LG WM 1485FHD Intelo Washer 7kg door error
Home Forums Public Support Forums Help And Support Washing Machine Help Forum LG WM 1485FHD Intelo Washer 7kg door error
  • #52042
    bruffy
    Please can anyone advise me how to rectify the fault on my LG ? The machine gets all ready to set off and then it flashes d e and I have to gently bash the door, where it latches, several times to make it start. Unfortunately it takes more and more bashes each time. I have not had it apart yet but feel sure it is going to be necessary. 🙁
    #310425
    helo_75
    you could try changing the door lock, that will do it
    open the door, release the spring from around the door seal, peel the seal back, undo the 2 screws on the lock and it should come out
    just make sure the plugs out
    #310426
    helo_75
    part number for door lock is 6601ER1001A
    #310427
    helo_75
    bruffy
    Re: LG WM 1485FHD Intelo Washer 7kg door error
    Thank you helo-75 I will do that. Thank you very much for the prompt advice Best wishes
    #310429
    Hi bruffy
    the fault will be either :-
    there is a pin that holds the door handle & pecker in place in the door assembly,if this slips out of place then this fault will occure,refit correctly and it’ll work.. numerous ones of this.
    the main PCB , the interlocks are normally fairly reliable on this model.
    bryan
    #310430
    Squidgy001
    Hi I was wondering how you got on fixing it, as I have the exact problem.
    Did you get the door lock part or was it something else?
    Many thanks,
    Sarah
