LG WM1171 FHB
  • #42542
    ray.t
    Hi, I went to one of these today thats doing funny things.
    The customer complained that the machine will not pump out and is showing an error code of OE which I think is not pumping as it should.
    I filled the machine with water and it pumped out just as it should nice and quick.
    I tried the machine on a spin and it wouldn’t spin but the motor is working ok for the rinse and wash. When I put it on the spin only cycle the pump was running but no motor action at all and the time on the display did not go down, it just stayed on 11 mins.
    Can anyone shed any light on this one?
    Thanks, Ray
    Lucky Goldstar
    #273862
    Gavpo
    Re: LG WM1171 FHB
    Hi. As a stab in the dark .Check the pressure system
    #273863
    BobHope
    Re: LG WM1171 FHB
    good call Gavpo
    hade this fault a few times and it was a blocked pressure chamber.
    Bob.
    #273864
    ray.t
    Re: LG WM1171 FHB
    Just to let you know it was indeed the chamber that was blocked, cleaned it through and its working fine now.
    Thanks For the help
    Ray
