Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › LG WM12397TD motor problems.
- This topic has 13 replies, 7 voices, and was last updated 17 years, 3 months ago by
aqualectric.
January 5, 2009 at 8:52 pm #42305
aqualectric
ParticipantLG WM12397TD washer. Serial no:- 508KWUC00782. 58WD2680.
This machine is the direct drive motor type. Customer reported a CE or LE fault – motor overload. I’ve looked at everything usual…. The bearings are perfect and the drum spins freely. Spin cycle starts, pump works fine. Then the stator is energised and the pulley locks solid with the magnetism and a loud “tinging” noise is heard. Sometimes the motor will turn the drum but there is a low, laboured sound from the coils and the PCB smells hot. The motor will ‘cut’ after a few seconds of running. All reminiscent of a induction motor coil failure. But…….
There are 2 PCB’s on this machine; one behind the fascia and a small square one with a large ferrite coil on it. I removed the drum pulley and the stator coils look as new. I can’t see anything amiss…….:?Any help please??
Thanks,
Steve.
Lucky GoldstarJanuary 5, 2009 at 8:55 pm #273060lerch
ParticipantRe: LG WM12397TD motor problems.
Hall sensor can go but normally is the stator. Pcb’s one is display and the other is the main pcb. 😀
January 6, 2009 at 9:18 am #273061aqualectric
Hall sensor? What does that do and what does it look like? 😕
Stator is around £90 + VAT from Connect; not too bad.Thanks,
Steve.
January 6, 2009 at 10:45 am #273062lerch
Hall sensor is screwed onto stator and detects the spin but even though LG say the stator never go’s it is always better to change as when I have changed the hall sensor it is very hit and miss.
January 7, 2009 at 12:39 am #273063alro
Had same fault a bit ago replaced stator with hall sensor in it worked find no stammer or clunk semes are the cheapest half the cost of connect
cheers alroJanuary 11, 2009 at 7:44 pm #273064aqualectric
The new stator sorted it….thanks guys!! 😀
Steve.
February 23, 2011 at 12:59 pm #273065davidelliot
Hi Guys n Gals,
I know this post is a little dated now, but I have a similar problem to this original post…
However; what I’m trying to find out is who is Semes in relation to spare parts? (from the quote; “semes are the cheapest half the cost of connect”)Any help appreciated.
February 23, 2011 at 1:19 pm #273066Specialist01269
Hi: Possibly http://www.seme.co.uk an Appliance / Electronic parts supplier to the Trade.
February 23, 2011 at 2:32 pm #273067davidelliot
Ah… thanks very much Specialist01269, I’ll take a look 🙂
February 23, 2011 at 2:32 pm #273068johnmac11
ParticipantFebruary 23, 2011 at 2:34 pm #273069davidelliot
Thanks for that johnmac11
February 23, 2011 at 2:42 pm #273070Specialist01269
Sorry Dave, same company but I did’nt realise they’d changed name.
Have’nt dealt with them for years.February 24, 2011 at 12:29 am #273071leavemetogetonwithit
They still have a few bits and pieces but you can’t find them by browsing, or I can’t, even though I’ve got an account. Only way is to find out OEM part number and put that in their search box.
Mike.February 24, 2011 at 11:54 pm #273072davidelliot
Cheers Guys
