LG WM1295FHB WASHING MACHINE
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries LG WM1295FHB WASHING MACHINE
  • #42822
    DAR01
    Machine faults out on Spin, fault code FE.
    The machine does not overfill,goes through wash and rinse parts of program OK.
    When it gets to spin it empties the rinse water, then it starts to fill with cold water and empty at the same time,with the cold valve being intermittently activated. (valve not faulty being switched apparently by relay on control board)
    This continues until the machine fault out.
    Anyone come across this fault before,suspect control board fault.
    Tried another pressure switch no change
    The only problem is when i checked the machine yesterday with no washing in machine, it worked OK.
    Mike :rolls: :rolls: :rolls:
    Lucky Goldstar
    #275025
    aqualectric
    Re: LG WM1295FHB WASHING MACHINE
    FE is an overfill fault. If the pressure bottle is clear and the pressure switch hose isn’t holed, then it’s got to be the PCB.
    HTH,
    Steve.
    #275026
    DAR01
    Thanks, just wanted to be sure, didn’t want to be stuck with a £140 board which i may never use again.
    Mike
