LG WM13150FB washer. Serial no:- 305KW00369. 77200305003369304094. 35WD3210.
SE fault recurring – only switching off at the mains stops it. This is the machine with the belt drive motor. Tried motor plugged / unplugged; tried supply cables; tried connections; tried for earthing issues…. all OK. Turn on machine, 3 seconds and SE with annoying beeping.
Do these motors ever fail? Would have thought it was pretty unlikely…… but if not that just leaves the PCB which is showing as obsolete.
Help please!!
Thanks!!
Steve.
