This one is odd…during the wash action it makes a real groaning noise which appears to come from the motor end of the drum as though the motor is running rough. It sounds as though the drum is rubbing the door seal but it clearly isn’t that. I suspect either the stator or pcb…has anyone else come accross this?
If not, it looks like a ‘throw parts at it’ repair 😕
YES YOU DO GET A WEIRD NOISE ITS AS YOU SAID EITHER THE STATOR OR PCB CHECK THE PCB THAT THE BIG CAPACITOR ISNT BLOWN BUT IF NOT IT CAN BE A GUESS WHAT ONES FAULTY
