LG wm1437
  • #43863
    streetlighter
    Hi all
    Got a LG wm1437 washer with a fault code AE
    ? is this a water leak & has any one been to one of these because I have never worked on a LG before.
    Any advise would be great before I call so I dont look a compleat prat.
    Ta
    Paul
    Lucky Goldstar
    #278857
    Re: LG wm1437
    This might be of some help, but probably not much.
    http://www.justanswer.com/questions/1no … ater-leaks
    Mike
    #278858
    Steven
    Re: LG wm1437
    Check Your email I have sent you the service manual.
    Steven
    #278859
    streetlighter
    Re: LG wm1437
    Thanks steven
    Problem was a water leak, couldn’t see it but I felt it in the floor pan.
    Found it on the element seal in the steam box, only leaked on steam wash. 😕 took some finding. 1/2 turn on ele nut job done 😀
    Paul
    #278860
    Specialist01269
    Re: LG wm1437
    Hi Steven: Is there any chance of having a copy of the manual off of you mate? I have 1 of these to go to on Tuesday that intermittenly dies off, so the manual may come in extremely handy.
    Thanks: Andy.
    restorer@tesco.net 🙂
    #278861
    Steven
    Re: LG wm1437
    Yes no probs will do it on monday
    Steven
    #278862
    Specialist01269
    Re: LG wm1437
    Steven wrote:Yes no probs will do it on monday
    Steven
    Hi Steven: Thanks mate I appreciate it, I haven’t seen one of these before so dont know how easy they are to work on etc & the manual may well prove extremely useful.
    Regards: Andy. 🙂
    #278863
    Specialist01269
    Re: LG wm1437
    Hi Steven: Thanks for the manual mate.
    Regards: Andy 8) 😀
    #278864
    lerch
    Re: LG wm1437
    If it is the steam version they have a major problem with the steam generator but will not say so. Everyone I have been to (6-10 units) has had the same fault water in base only after using the steam gen. Leaks along the seal normally and you have to replace the whole unit. Otherwise very good. 😕
