LG WM1437RFD (Snr 611KWP00130)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries LG WM1437RFD (Snr 611KWP00130)
  • #70341
    rocker
    Called today to fit new pump, was unable to gain access..I removed the facia contol panel, the 2 grey plastic side posts but unable to release the front metal cover as there are hidden screws that hold it to the side panels.(cant access)
    could anyone advise me on this or send me a breakdown diagram.
    thanks John.
    ableappliances@gmail.com
    #377840
    rocker
    Re: LG WM1437RFD (Snr 611KWP00130)
    Anyone please..connect cant help !!
    #377841
    bazza500
    I’m not sure if it is the correct model but some have a screw behind the filter flap near the bottom and 2 at the top(at each corner then the front panel slides up about half an inch and lifts off.
    #377842
    rocker
    Thanks for your reply, but this must be a different model
    there are no screws at the top of each corner and also there are 2 black hidden screws with a hexagon top about a quater of the way from top but cant get access !!
    #377843
    blackandwhites
    Again,I’m not sure of model.
    Once you remove all screws are you sure you can’t then lift whole of front panel which then slides off pins.These pins may be the bolts you are talking about a quarter of the way down.
    #377844
    BobHope
    Hi Rocker,
    PM me an email address and i will forward you some info.
    Bob.
    EMAIL SENT
