LG WM1465FHD
  • #6986
    tonyclifton
    Blocked
    Got above machine to look at fault is makin noise when spinning on full custmors says sounds like bearings. I was told these were reliable for bearings? any advice on this one as cant get info on LG machines 🙁
    #120759
    Dave_Conway
    Re: LG WM1465FHD
    As it’s a 1400 rpm spin Tony, it’s more likely to be nothing wrong with it or the shocks are in need of the updated one’s.
    Coins in the pump are often described to us as noisy bearings as well 😉
    #120760
    tonyclifton
    Blocked
    Re: LG WM1465FHD
    Cheers dave
    where would i find tech details on LG appliances? AS seem to be getting loads just lately
    #120761
    Dave_Conway
    Re: LG WM1465FHD
    The LG website only Tony.
    If you’re getting these calls via CDSL they should be able to provide you with the relevent information, otherwise contact LG directly for a spares account, once you have that you have full access to everthing.
