Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › LG WM1480 FHD washing machine showing ‘DE’
- This topic has 10 replies, 7 voices, and was last updated 16 years, 5 months ago by
boselecta.
October 24, 2009 at 9:06 pm #49594
boselecta
ParticipantLG WM1480 FHD
Visited this machine last week, not starting, showing ‘de’ (door error).
I replaced the door interlock and the machine now starts ever time.The customer has now called me back and says every time she uses it, it stops mid cycle and ‘DE’ comes up. She then selects spin and it completes the cycle and finishes.
Any ideas folks?
October 24, 2009 at 9:10 pm #300370Jazzmeister
ParticipantRe: LG WM1480 FHD washing machine showing ‘DE’
DE= Drain error
LE = Lock Error
UE = unbalanced loads…hope this helps…..check the pump!
Jazz!
October 24, 2009 at 10:34 pm #300371boselecta
Participantthanks Jazzmeister,
thought ‘de’ was door error, as interlock was definatly at fault, will go back and investigate further.October 25, 2009 at 6:03 pm #300372DentedPorsche
Hiya,
LE is lock error but refers to the motor, not the door lock. Normally the hall sensor at fault.
DE is a door lock error.
OE is a drain error.HTH
BrianOctober 25, 2009 at 7:39 pm #300373funkyboogy
D.E drum error had it few times .. you will need to change the stator or the sensor that clips onto stator ..
ally
October 25, 2009 at 10:05 pm #300374boselecta
ParticipantThanks for the replies but a bit confused now:
‘DE’=
drain error and door lock error and drum error!October 26, 2009 at 12:35 am #300375Penguin45
Yup, it’s come up before and no definitive meaning was ever agreed upon.
October 26, 2009 at 4:45 am #300376bigsmokepiker
ModeratorRe: LG WM1480 FHD washing machine showing ‘DE’
Down this way
OE- Outlet/Drain error
dE-Door Error Lid error for top loaders
LE-Motor Error
Same error code for all LG Front Loaders &Top loadersOctober 26, 2009 at 12:40 pm #300377funkyboogy
yip is abit confudleling…
all i can say we have had it a few times , been caught out fitted door locks etc … now we fit stator every time
ally
October 26, 2009 at 7:16 pm #300378DentedPorsche
Hiya,
LE is definitely a lock error on the motor. The hall sensor can’t signal where the motor has parked.DE is definitely door error
Brian
October 26, 2009 at 8:19 pm #300379BobHope
DE is the door lock error
on the manual type of door lock it is usually the handle pin that has worked loose.on the electic opening type ive had the door interlock fail and the mains input filter panel cause the problem, let the door lock then tap the mains input panel on the to rh side of appliance if the door unlocks its a dry joint on the pcb (replacement is the only cure.
LE is a motor related fault. (hall sensor)
Bob.
