LG WM1480FHD
  • #59124
    mic
    Hi Can anyone give me the answer to the possible cause of a LG WM1480FHD I’m looking at, you have to repeatedly press the on/off button before it will start.
    Thank you
    #337007
    Re: LG WM1480FHD
    Tactile switch on fascia board is likely culprit.
    This thread may be of interest.
    Mike.
    #337008
    mic
    Re: LG WM1480FHD
    thanks for reply, once it has switched on it will turn on and off as normal, it is only when it has been left off for some time it is reluctant to switch on again. It makes no differance if you push switch firmly or gently it just needs a lot of pushes
    #337009
    Re: LG WM1480FHD
    Yep, that sounds like a faulty tactile switch alright.
    Mike.
