LG WM1480FHD
  • #54002
    spimps
    7kg washer which starts and then gives fault for door,which is locked and checked power from door lock return yo pcb,all connections OK so looks like control board.
    Anyone have knowledge of the price as it looks BER.
    #317998
    BobHope
    Re: LG WM1480FHD
    hi spimps,
    what is the error code showing on the display.
    Bob.
    #317999
    spimps
    Re: LG WM1480FHD
    BobHope wrote:hi spimps,
    Bob.
    It is “de” ,door open according to booklet.
    BG
    #318000
    BobHope
    Re: LG WM1480FHD
    well thats a door lock error code, some people get confused with the DE and LE error codes 😉
    have you looked at the door latch pin as this somtimes works its way upwards and out of its eye retainer, then the latch hook does not make the door lock and it ulocks soon after its started.
    Bob.
    #318001
    spimps
    Re: LG WM1480FHD
    Thanks for your suggestion,the door does lock and stays locked after the error code comes up so I didn’t think there was a mechanical issue with the door lock,worth a second check perhaps though.
    BG
    #318002
    Re: LG WM1480FHD
    Would it not be worth trying in a door lock or at least bridging the old one just to be certain that it isn’t the lock at fault?
    From Connect,
    6871EC2005B
    PWB(PCB) ASSEMBLY,DISPLAY
    Display module laundry WM1480
    From £40.66
    SRP: £61.65
    In Stock
    6871EC1099B
    PWB(PCB) ASSEMBLY,MAIN
    Module:PCB laundry WM1485
    From £107.87
    SRP: £163.55
    In Stock
    Would think it also worth a careful examination of pcb’s to look for visible damage which may be repairable.
    Mike.
    #318003
    funkyboogy
    Re: LG WM1480FHD
    DE ..DRUM LOCK ,
    had this a few times ,, stator fault you can buy the stator sensor seperatly so ive been told..
    ally
    #318004
    BobHope
    Re: LG WM1480FHD
    DE is a door lock error
    LE is a motor locked error
    lot of people get confused with this some places have these two error codes reversed.
    Bob.
    Lucky Goldstar
    #318005
    funkyboogy
    Re: LG WM1480FHD
    dont know what causes this but ive had de at least 4 times and in all cases its been the stator..
    1st one i went back with door lock , but didnt work..
    but i would try door lock on this one..also worth getting part no for stator sensor , if cheap enough take both
    fb
    #318006
    bazza500
    Re: LG WM1480FHD
    leavemetogetonwithit wrote:Would think it also worth a careful examination of pcb’s to look for visible damage which may be repairable.
    Mike.
    Very difficult on LG boards as they cover them in that solid jelly like gungy stuff.(I’m sure there must be a technical name for it)
    #318007
    spimps
    Re: LG WM1480FHD
    Mike.
    It is the board,10 year old machine so BER, the board is immersed in a solid silicone/shellac type material.
    #318008
    Re: LG WM1480FHD
    I had similar this last week. Reported fault was DE intermittent and becoming more regular. Fitted new lock Saturday – fault still there and became worse in that machine would not even turn on!
    Took boards out. Did a functional check on tactile switches and found most of them to be intermittent. then looked at jellied board and could see signs of burning in the jelly. Took both boards home.
    This morning, re-tested tactile switches and replaced dodgy ones. Cut away plastic from back of power board around burn area and tried to remove jelly from printed side but gave up. Decided it might still work anyway. And after putting it all back it works fine.
    I think the brown marks in the jelly were from a big blue suppressor type capacitor thing and if the machine fails again I’ll try and cut that out and join a new one in.
    Reason for switches failing is probably damp environment. Some of the external legs of the switches were green with oxidation.
    Mike.
