lg wm1480fhd
  • #55721
    need a rear helf tub for lg auto WM1480 FHD
    part number 3045ER0002A
    got a price from seme nedis site of £75.88 plus all usual
    since this a public site are there any better prices i have seen a flyer seme put this part on so it may have been on special offer
    Qualtex cant supply i tried
    any other ideas to reduce cost
    loaf
    Re: lg wm1480fhd
    Knock out the bearings, BRG9111 from Connect and also replace the tub half seal 5031682198476.
    #324908
    Re: lg wm1480fhd
    unfortunatly bearing behind seal can be lifted in and out with 1 finger and there is 0.5mm of play so sleeve is damaged.
    dont know how this has happened. Did not even know machine had a bearing prob till it started to spin. it was ok on wash and very high spin but made a noise on the way up. its a nice machine works well and is a shame to scrap it but at over £90 for parts its a bit silly. what i need is a scrap machine with other faults and make 1 good one
    twicknix
    Re: lg wm1480fhd
    Has anyone got a spare tub for LG1480?
    The one I have got a worn sleeve. The bigger bearings can be easily lifted with one finger.
    Don’t really want to scrap it.
    #324910
    QUICK FIX
    Re: lg wm1480fhd
    loctite them in
    #324911
    twicknix
    Re: lg wm1480fhd
    QUICK FIX wrote:loctite them in
    What? What you mean loctite them in? I admit it does need some filler or a wedge to hold the bearing race tight, but are you sure it will withstand 7kg of clothes plus water tossed about at 1400rpm?
    #324912
    Re: lg wm1480fhd
    It will need a new rear half.. Loctite doesn’t work on housings that are worn. You’ll only have a recall within days even if you could get them to sit firm.
    Bryan
    #324913
    twicknix
    Re: lg wm1480fhd
    Thanks Brian, my thoughts exactly. What a pity!
    #324914
    QUICK FIX
    Re: lg wm1480fhd
    done it before never went back to them
