LG WM1480FHD Bearings
  • #35688
    Toni
    Has any one changed the bearings on one of these ?
    What are they like?, it looks like a tub job. If anyone can let me know of anything I should look out for or is it best just to change the rear 1/2 tub or the individual bearings
    Regards
    Toni Paz
    #247614
    boselecta
    Re: LG WM1480FHD Bearings
    I have changed the bearings on these, it is a tub job. Make sure you get the right bearings for them as a few kits 4 including WD bearing kit. Hopefully you wont need to change the cross piece as its really expensive and makes it not viable. I can recomend a good place to get the bearing kit if you need.
    Not a too bad tub job really, fairly easy to take of and replace the direct drive motor and plate.
    #247615
    Hi Tony
    I might have the complete inside assembly for thisI will have a look tomorrow,might be able to do a good deal on it.
    Bryan
    #247616
    Toni
    Thanks Brian,
    sorry for taking so long to reply but I have been really busy this week.
    If you can sort this out for me it would be great. If not the part numbers would be good & where is te best place to order them from.
    Unfortunately this wont be a money job for me as its for my sister
    Regards
    Toni
    Lucky Goldstar
