called out to above machine today,drum turns freely with no bearing noise or wear.when the motor receives power to tumble it jams up as if the magnetic field is upset.after a short time of this it aborts with the LE error code.can any one help as i am unsure on what to try next.thanks
its normally the hall effect sensor on the motor that causes this fault, it is part of the motor assy, but on that note i have at one time been caught out and it turned out to be the PCB 😳
good luck.
Just like to say that i have now fitted a new motor and all is fine.took a look at the hall effect sensor on the old motor but could not see any physical fault.
Thanks to everyone that helped.
