LG WM1485FHD programme help.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries LG WM1485FHD programme help.
  • #34470
    aqualectric
    LG WM1485FHD washer. Direct drive motor type.
    I have acquired this machine and all seems perfect. While I had the machine on a test program, I tried to stop the cycle to drain the machine. I pressed the ‘Pause’ button but try as I might, it seems as if once a program is set and started, you can’t alter or abort it. Surely I’m missing the bleedin’ obvious and there must be a way to do this?
    Pray tell!! 😕
    Thanks in advance,
    Steve.
    #242800
    lerch
    Re: LG WM1485FHD programme help.
    You cannot change program without cancelling it – just switch it off and re-select. 😀
    #242801
    aqualectric
    Thanks for the reply, Lerch!!!
    I wanted to select a spin only cycle – but you seem to only be able to do complete start to finish wash / rinse / spin.
    Can’t be done I suppose. Disappointing omission considering what it would have cost new. 🙁
    Thanks,
    Steve.
    #242802
    ELDAR59
    i have one of these and i can select spin only cycle.
    turn the machine on and without selecting a program, press the spin button. pressing again will alter the spin speed.
    press start and off you go.
    cheers.
    #242803
    lerch
    Sorry never realised you wanted to do spin only.
    Alf_uckem is correct but not all lg can select spin only on some you have to do rinse and spin @ 19mins pain really. 😀
    #242804
    Holding in the start button will stop the program and pump out whilst the button is depressed but you need to hold the button in for approx 10 seconds.
    Bryan
    #242805
    lerch
    thanks r600a you learn something new everyday. 😀
    #242806
    aqualectric
    Thanks Brian!!
    You do learn something everyday!! It is always useful to know how to fill and empty a machine after a repair quickly and easily.
    Cheers for all the replies!! 😀
    Steve
