LG WM16110FD (Direct Drive)
  • #29759
    Toni
    I have one of these that the drum has got stuck.
    I have checked that there is nothing in between the drums (as far as I can see).
    Could it have a problem with the drive unit ? I have not done one of these before so I haven’t yet taken it apart
    If it is a drive unit, what are they like to do ? and how much is it likely to be ?
    Any help would be very much appreciated
    Toni
    #224621
    bazza500
    Re: LG WM16110FD (Direct Drive)
    Hi Tony,
    These are easy to work on. Take the middle nut off the drive unit on the back and the outside part should pull off. you will be left with the stator bolted to the outer tub and the spindle of the drum in the middle. from there you should be able to see anything that is sticking it. Try turning the drum with this off and all should be revealed unless the bearings have siezed.
    Hope this helps, Barrie
    #224622
    Toni
    Thanks Barrie
