LG WM16220FD. Pump(s) make grinding noise. What replacement?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum LG WM16220FD. Pump(s) make grinding noise. What replacement?
  • #64524
    Hpad
    I have an LG direct drive washing machine.
    Makes a lloud grinding noise when in wash cycle/agitating.
    But otherwise quiet,
    Spin is very quiet, and drum rotates easily.
    I suspect the water pump needs replacing.
    BUt before I dismantle it to check, can anyone confirm
    (1) does the WM16220FD have one or two pumps? ( i.e. is the recirculation/jet pump the same as the one that drains the machine)
    (2) what is replacement partnumber for the pump(s)
    #357303
    bazza500
    Re: LG WM16220FD. Pump(s) make grinding noise. What replacem
    If it’s fine on spin then it will be the recirculation pump. Both pumps are the same. Part number 4681EA2001E
