Re: Liebherr CNPes 3867
I posted a similar question about my FF (again a Liebherr – icbn3056). From the self tests I found online I came to the conclusion that it was a fridge sensor, not sure which one as there are a couple to change so may just go with two to save taking it apart twice. Right now I have switched the fridge off as the freezer seems fine unless the fridge temp increases then the freezer follows suit as I assume the evap plate starts freezing to try and control the fridge (mine has a single compressor and evap and yes could be one of these but will go for the cheaper fix first).
Like you a number of views but no suggestions or even confirmation of the part number so I can try and source myself… as Liebherr will only suggest 2 companies near me and both have very poor reviews so will give them a miss… but you may have better luck if you call Libherr UK.
Hope you get it sorted… and if you do please let me know how!!
