Liebherr Comfort refrigerator freezes.
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Liebherr Comfort refrigerator freezes.
  • #93241
    LeeBarton
    I have a Liebherr Comfort IKS 257 larder refrigerators that keeps freezing the contents of the fridge. there is no freezer compartment and the fan comes on when the door is closed. I suspect it is the temperature sensor, but would appreciate any suggestions. If it is the sensor, is it an easy DIY job to replace it, as the fridge is in a holiday home in France? this is my first post on this forum.
    #453669
    deen pande
    Re: Liebherr Comfort refrigerator freezes.
    We are having Liebherr freezer/fridge
    Details are as follows:
    BACK SIDE Lebel:
    9268105-02 F9007080-00
    GG5210-20J 001 22071001352 W09 A0713
    INSIDE LEBEL:
    G521620C/001
    936562901/7723/0707
    COMPRESSOR
    NLX15KK DANFOSS 105H
    R600a 6912 7A6PE127
    MADE IN SLOVENIA
    FAULT:
    NOT WORKING.
    WHILE SWITCHING ON …..
    COMPRESSOR JUST STARTING AND STOPING COMPLETELY.
    DISPLAY BLINKS WITH TWO _ _.
    PLEASE ADVICE WHICH PART WE SHOULD REPLACE.
    START RELAY OR ELECTRONIC CICUIT BOARD. ( 6114431)
    #453670
    Tony R
    This is a Liebherr commercial freezer, the 2 dashes indicate the unit is not at the correct temperature, you need to find out why the compressor is not running.
    Is it losing voltage or is it or the relay failed. Only an inspection by an Engineer can tell you what has failed.
