Liebherr Cpes4613 index 20b /147 alarm beeping
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Liebherr Cpes4613 index 20b /147 alarm beeping
  • #88635
    slyp98
    hi guys , this one has the beeping 3 times and the super freeze led flashing , does anyone know which sensor this relates to thx
    #438827
    ELDAR59
    Re: Liebherr Cpes4613 index 20b /147 alarm beeping
    Hello, there’s normally something else to act as an indicator, like a flashing temperature indicator.
    It’s more than likely the evaporator sensor anyway.
    You could go to the pcb, take off the evaporator sensor connector (it would be the one marked green) and see if the alarm condition changed.
    If it didn’t, then that’s your problem.
    Cheers.
    #438828
    slyp98
    thanks Eldar 59
    #438829
    slyp98
    sorted it was air temp sensor in fridge compartment , the evap sensor is fitted at the rear, beside the compressor pushed up into the cavity !!!!
